Hier à 21:09 par vinZ
Drift Tamyia
Drift Tamyia
Message par yapluka le Jeu 11 Mai 2006 - 2:51
Bon me frapper pas mais moi j'aime le drift est avec un MT .... y a pas moyen
De plus j'aime BMW est je viens de tomber sur une video
http://www.filewire.com/download.php?id=be29618d1c6748abffd8b6f
Dedans ont peu voir une Tamyia
Donc j'ai fais ma petite recherche pour savoir si sa drift ce truc ou pas est j'ai trouver ca
Tamyia:
The Tamiya TL-01 is a shaft driven car just like the newer TT-01. Both cars are cheap in price wise and are perfect for a new person to R/C’s in general. Also Tamiya makes some of the best high quality R/C touring cars on the market. These include the TRF series of cars.
TL-01: $84.99
The TL-01 is a relatively old design, and was first released in '97, but it's still a VERY good chassis. It's tried and tested, so there are many replacement parts and hop-ups, so the design HAS to be good if it's still so popular. It's a monocoque chassis which is all plastic. It comes with friction shocks which are not adjustable and a Mechanical Speed Control (MSC from now on) and a 540 stock silvercan motor, slicks and wheels.
There is a WIDE range of bodies for the chassis to choose from. So you really have to go to TowerHobbies and pick the one you really like the best, there are just too many to list.
This kit is also a very good drifter, just tape up the tires and you're away! And it's dirt cheap too!
Requires
2 Channel Radio set (and batteries for it)
Two servos (one is you're going to use an ESC)
Lexan paint for the body
6-Cell battery pack
Charger (peak charger is recommended)
the stock MSC can be replaced with an ESC, which is recommended.
TT-01: $84.00
The TT-01 is a new chassis in the cheap end like the TL-01. It's a tub style chassis "similar" to the TC3. It's got friction shocks which aren't adjustable. Like the TL-01 it includes a motor and an MSC, which most likely are the same as the TL-01 kits. It also comes with foam front bumpers, so if you hit something, it won't damage the chassis (although it doesn't mean that you should run your new TT-01 into a wall just for fun!). It comes with a clear body, although TowerHobbies only list the F60 (Enzo) and the 350Z Race Car, Tamiya have made a few other bodies including the Subaru Impreza, Mercedes CLK-DTM, Nissan Skyline R34 JGTC Edition, Honda NSX Raybrig JGTC and Ford Focus RS WRC.
Requires
6-Cell battery pack
N.B! Tamiyas site lists some of the TT-01 kits with the MSC and some without! So check this before you buy one!
TA-04: $269.99
The TA-04 is a race chassis, so it's got a fully adjustable suspension, with camber, toe-in and ride height. It's got a full ball bearing set a motor heat sink and hard springs in the oil-filled shocks, so the suspension is ideal for drifting.
Requires
Two servos
Electrical Motor
6-Cell battery pack
ESC
Probleme je capte rien a l'anglais ou tres peu donc j'aurais voulus savoir si d'une la Tamyia peu etre une bonne base pour faire du drift et de deux qu'est ce qu'il faut modifier ?
Y a un shop dans le coin qui vendrais du tamyia ou vos mieux regarder direct sur le net ?
Merci d'avance pour votre aide
yapluka
Masculin Nombre de messages : 39
Re: Drift Tamyia
Message par Riphraph le Jeu 11 Mai 2006 - 10:28
salut.
Pour commencer, pour ceu qui on des problemes en langue etrangere, google nous met a dispo un traducteur de texte ou de site bien sympatique.
What a Face le voila: http://www.google.fr/language_tools?hl=fr What a Face
ensuite pour ton drifft je pense que n'importe quel voiture piste avec des pneux speciaux fera l'affaire.
christian a la Boutique du modeliste a des voitures 1/10 de se type.
Apres pour les pneux fau se renseigner pour trouver le type ensuite christian pourra s'en doute te les commander...
Va lire sa: http://www.rc-bot.com/drift.php?part=intro
http://www.rc-bot.com/drift.php?part=materiel
http://www.rc-bot.com/drift.php?part=pneus
Va lire sa aussi: http://eaglexangel2.free.fr/rcdrift/index.php?file=Sections&op=categorie&secid=3
A+++++++++++++++++++++++ pig pig pig
Riphraph
Nombre de messages : 322
http://yapluka-bf.societeg.com/
Drifts
Message par Cardan-67 le Jeu 11 Mai 2006 - 20:32
Salut les MT'istes ,
Comme ils disent le drift marche bien avec des voitures éléctriques et pour info chez christian il y a # modèles de la marque TAMIYA ( ceci est une tres bonne marque).
Le plus simple est de mettre des pneux dures mais apres il reste à maitriser le bolide. Car pour avoir fait du 1/10 eme thermique je peux vous dire bonne chance.....
A +
Marc
Masculin Nombre de messages : 1829
Re: Drift Tamyia
Message par Kaizer le Sam 20 Mai 2006 - 0:21
Salut Psyko, un pti lien pour voir ce ke sa donne en vidéo....ta meme les lecons avec....mais c'est japonais... lol!
http://rc-car-videos.blogspot.com/2006/05/rc-car-drifting-video-learn-how-2.html
Kaizer
Masculin Nombre de messages : 235
Re: Drift Tamyia
